跳转到主内容
This device is an at-home beverage machine made by SodaStream. The purpose of this device is to make carbonated beverages in the convenience of your own home with the use of syrups and the machine. This particular model was originally manufactured in approximately 2007.
11 个问题 查看全部
Whats the difference between a broken seal and old washers?
My machine is not producing carbonated beverages, I have had this machine for a long time and have had no problems. My CO2 tank is full and I can not determine any other issues.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This problem could be caused by either worn out washers or a broken air tight seal. The main difference is that a whooshing noise will be heard if the air tight seal is broken. Try carbonating a beverage and listen very carefully; if the air tight seal is broken the noise will emit from the adapter.​
这个答案有帮助吗?
得分 1
添加一条评论
our Sodastream works well, however the seal at the top of the bottle entry leaks and water "blows by "
and leaks down the bottle and makes a mess.
I cannot find a replacement gasket online???
cujim
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Katie Fetters 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,481
