跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Computer is unable to detect HDD in optical bay enclosure
Hi there!
I’m trying to install a SSD into my Macbook Pro (15” Unibody early 2011), but I’m having some issues. My goal is to use both the new SSD and my old HDD and make a fusion between the two to be able to use both the space and the speed.
The SSD is an 'INTEL 530 SERIES 2.5" 120GB SSD SATA/600 MLC BULK’.
I bought an iFixit upgrade pack with an optical bay enclosure, and first I put the SSD into the optical bay and replaced the optical drive with it. The computer didn’t find the SSD at all.
I then replaced the old HDD with the SSD and put the HDD in the optical bay instead, and was now possible to find the SSD, format it and install OS X without any problems. BUT the computer won’t find the HDD in the optical bay enclosure either. The only hard drive I’m able to find in Disk Utility is the new SSD.
I’ve followed every step in this guide:
Installing MacBook Pro 15" Unibody Early 2011 Dual Hard Drive
Any suggestions to what the problem might be?
Thanks a million!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You might get faster/more accurate results to contact iFixit customer service directly using the link below.
This is the volunteer DIY help forum. We are not affiliated with iFixit directly in any way.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 0
1条评论:
Thanks very much, machead3!!!
完成的
添加一条评论
添加你的答案
Fanny Ovesen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 159
