跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
How to replace MacBook White Early 2009 Enter Key
Hi,
I've found a guide to replace Macbook White Keyboard. But the key used in the guide is the "Z" key. I have my Macbook White "Enter" key detached accidentally and want to fix it myself.
The "Enter" key seems has a different hook from the "Z" key so it suppose to has a different way to replace it.
Can you help me fix this problem?
Thanks.
Frankie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Yes - it's slightly different.
Examine it the current one closely as you remove (lift it off) there are alignment pins that must go back into the guides (arms/holes) as you insert the new key-plate. If your new key has the key-plate you can see what I'm talking about. If the replacement key-plate is missing the metal guide the old one will snap out and into the replacement.
If you mug it up it won't sit level or pop up/down, just have another go at it. It takes real effort to damage the replacement key.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frankie Sirait 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 533
