跳转到主内容
Originally released in 2001, identified by model number VT750DC.
3 个问题 查看全部
What do I do if the motorbike does not stay on?
While riding the motorbike, the engine will shut off and it will not start back up. When I try to start it back up, it makes a constant continuous chugging noise but the engine will not turn over.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
If the bike is carbureted and has been sitting for an extended period of time there is a chance that the float valve is sticking in the closed position. This will prevent fuel from filling up on the carburetor bowl, and starve the engine of gas. I would disassemble the carburetor and give it a good cleaning with a can of carburetor cleaner. A lot of times a dirty carburetor causes similar fueling issues on older motorcycles.
这个答案有帮助吗?
得分 2
添加一条评论
It sounds like the gas tank is empty. Switch to the reserve tank by flipping a switch under the gas tank on the left hand side. This will give you enough gas to get to a gas station to fill up the tank. If this does not solve the issue, refer to the troubleshooting guide for additional information.
这个答案有帮助吗?
得分 0
添加一条评论
It could be a battery, electrical or a fuel problem. First. Hook up a volt meter to the battery and check the voltage. It should be around 12.5 volts. Then try cranking it, it should drop a little, if it drops considerably, like down to 8 volts, you should charge the battery. Next, try spraying some starter fluid into the carb and see if it starts, it will likely cut back off shortly. If it does, that confirms a fuel issue — but it could be anything from the fuel filter to a clogged carb. Electrical—I’m not even going to touch!
这个答案有帮助吗?
得分 0
1条评论:
Try the starter fluid before attempting to take the carb apart. The last thing you want to do is rip that thing apart, only to find out that was NOT your problem.
完成的
添加一条评论
添加你的答案
Daz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 598
