跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 个问题 查看全部
问题已关闭
Wi-Fi "No hardware installed" message
Hi,
I have to replace my Wi-Fi card on my MacBook Pro 15" Unibody 2,66 GHz Mid 2009 with Antiglare screen.
When opening it, i've found the BT card but not the Wi-Fi.
I've been told that the card is in the display. IS it really ?
I've checked the different repair manuals but didn't found the right one to fix my problem.
Any idea ?
Thanks for your answer.
Regards
Emmanuel
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sadly Yes you need to pull the display as the AirPort (WiFi) board is located in the Clutch cover.
For some reason the guide is gone from the site (its the same for either Glossy or Anti-Glase models).
Here is the needed steps with very little difference: MacBook Pro 15" Unibody Late 2008 and Early 2009 Airport Card Replacement.
The AirPort part you'll need is Apple PN: 661-4766.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Sure its not a software issue? If so is this your machine guides are listed under part?
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
2条评论:
Hi machead3,
Thank you for your answer but it doesn't solved my problem.
Before asking for help, I've tried to upgrade my OS and checked for repair guides…
The problem is still the same...
完成的
If by "upgrade your OS you meant move to Mavericks or Yosemite that could be part of your problem. Mavericks had a lot of "undiscovered features" on older boxes with network drops, sleep/wake issues among them. Though a Mac user for decades I would not be surprised to find many similar problems with Yosemite - based on the ball drops of Mavericks and IOS 8. As with WinDUHows of old I would not move until service pack (update) two has been released. Go back to the OS you were running whatever it was
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 1,159
