touch screen dont work after changing home button
i change home button after the touchscreen dont work at all so i order a new one and change the complet lcd digitalyzer and still not working
Maybe you should check if the touchscreen FPC connector is well, if there is the pin is broken.
这个答案有帮助吗?
For the 4 if the digitizer connection gets scratched or bent bad enough it can cause the screens digitizer to stop working properly. If the flex is okay check the pins like Sophia said to and if those seem good then the board may have be damaged sometimes during the repair.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 117
