跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
问题已关闭
I've got beer in my MacBook,
Hi,I've got some beer onto my macbook,took it apart dried it at least for 4 days put it back together.Turned it on,hard drive works,fan works ,stanbylight is on but the display stays black and there is not any starting sound.Could anyone help me what to do or what to change thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
More than likely your backlight or inverter is shot.
How to diagnose.'' If you can see a normal image on an external monitor it is not your GPU/VGC. (if you see nothing there - bad news - the GPU/VGC is shot and you need a replacement logic board)'' The problem may be the data display cable/connector, the inverter board or connector.
Use a Mark I Eyeball and magnifier - look for corrosion, burn marks or swollen components.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 54
