跳转到主内容
Razor's A2 kick scooter was released in 2000, replacing the classic A model. Improvements from the original Razor A include a spring suspension and an added wheelie bar.
3 个问题 查看全部
问题已关闭
Why do my wheels wobble when going down a hill?
Whenever I go down a large hill, my wheels starts to wobble and shake uncontrollably about half way down the hill. This problem only happens going downhill and makes the scooter very difficult to control.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
When you say wobble, do you mean from side to side, or is it more of a vibration?
If it wobbles:
Take a look at the wheel and see if it can move bend from side to side when you use your hands. It should be nice and stiff with no play.
If it bends a bit and you have the tools, tighten it up. If it is tight but still wobbles, take the wheel out and check the clearance between the bearing and the wheel, it should be a nice tight fit. If it isn't you might need a replacement wheel.
If it vibrates:
It's most likely a flat spot on the wheel. The alternative is the wheel is out of round, if the wheel is new it might have been made like that (poor QC).
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 113
