跳转到主内容
The Asus X551CA is a 396.2 mm laptop computer with convenient features for everyday use.
20 个问题 查看全部
How to install 8GB Ram in Asus X551CA?
Hi, im planning to buy 8GB RAM memory for my ASUS X551CA laptop.
How to install the 8GB RAM Memory in X551CA Motherboard ASUS Laptop? and what is the limit of Memory Slots of ASUS X551CA Motherboard? is it 4 or 8 GB only? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
We need the full model name like X551CA-XXXX.
完成的
asus xx51cap
完成的
email me at denznewgate25@gmail.com form ore information about my laptop :)
完成的
what about this one x551ca - sx014h
is upgradeable to 8gb
完成的
Hello
Is it possible to update RAM in Asus X551CA-SX030H?
in specification there is information that can take up to 12GB
Thank you for info
完成的
添加一条评论
4个答案
最有帮助的答案
4 GB is soldered onto the motherboard. No slot for expansion. So if the ram is bad, get a new motherboard or just throw it away.
这个答案有帮助吗?
得分 4
添加一条评论
I know this is an old post but online there are different answers to this question. I am adding this in case someone needs the ultimate info:
The asus x551ca-sx024h PCB rev 2.2 doesn't have any additional slot, see the pictures, in the last one you can see that the slot is empty and the RAM is soldered directly in the PCB
这个答案有帮助吗?
得分 2
添加一条评论
the RAM limit on your notebook is 8GB so, you can upgrade your RAM, its really simple to change it. if you haven't bought the RAM the check this crucial link http://www.crucial.com/usa/en/compatible...
这个答案有帮助吗?
得分 1
添加一条评论
The ram slot is on the bottom of the motherboard. There is no access panel so the motherboard has to be removed and RAM added.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
denznewgate25 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 22
总计 14,311
