跳转到主内容
The Kodak EasyShare Z740 offers an impressive feature set, easy-to-use controls, and a powerful zoom, making it a good choice for anyone looking for a simple camera with room to grow.
Why is my device not turning on?
I press the on/off switch and nothing happens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
2个答案
已选择的解决方案
There are many explanations for this problem, but lets start with the easiest. Make sure to hold the power button for a few seconds rather than just pressing it. Next, the problem can be the batteries. If you notice they are dirty or messed up in any way, replace them. Also, if you do not notice any problems with the batteries, try removing them and putting them back in the correct pole direction. Finally the last two solutions to the problem are making sure the camera is charged by attaching the camera to the charger, and the last problem is the most serious and may require you send the camera in for repair, a bad logic board. This is an important part of the camera and you may cause more damage than good trying to replace it if you are not experienced in doing so.
这个答案有帮助吗?
得分 5
5条评论:
thank you this was very helpful :)
完成的
how much would it cost (sending it to repair)
完成的
I have all of this right, and I think my logic board is broken, but I can't afford to replace it. Any other fixing solutions than sending it in for repair?
完成的
thanks for the info. but I'm having all the symptoms as well.
完成的
This simple statement is useful for normal people, as for  my, which is electronicien, I find it insufficient, I ask a presentation following the problem with the synoptic or schematic diagram of the camera.I do not know anything about the technique of the cameras .I thank you in advance.
完成的
添加一条评论
get a new one it is easier
这个答案有帮助吗?
得分 1
1条评论:
I have a new one and still won't stay on.
完成的
添加一条评论
添加你的答案
Kirsten Price 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 35
总计 3,783
