跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
squares on the screen after battery replacement
Hello everybody.
I recently got an iphone 5s with a broken screen. I ordered a screen online and replaced it. It worked perfectly well except the proximity sensor that was not switching off when calling.
After a quick search online I managed to find the issue and I decided to order a new battery as well as I though mine was not lasting long.
I received the battery yesterday and opened the phone again, I replaced the proximity sensor and changed the battery of the iphone.
When I reassembled the phone and turned it on, I had some squares displaying on the top of the screen.
I though it was because the display connector was not properly connected, so I disconnected it and reconnected it. When I turned the phone on again, the squares are still showing up.
I took a photo of the screen displaying the square, you can see it here http://postimg.org/image/h7kq92sy3/
According to you, what's wrong ? What should I do ?
Thank you so much for helping me
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
My iPhone 5s can't turn on... after connect the charger there apple symbol appear and after there is black lines and square are appear....so what I do
.... this is software or battery problem tell me answer
完成的
添加一条评论
5个答案
已选择的解决方案
Hi,
It is either the screen is not connected correctly or it is a faulty LCD, I would try and clean the connectors first with 99.9% isopropyl alcohol, and then reconnect the screen, if this does not work then I would try a new screen. :-)
这个答案有帮助吗?
得分 2
添加一条评论
It's the screen. The connector is not fully making contact with its connector. When putting the connector down, run your finger from let to right to ensure all the pins are making the connection. You should hear 2-3 clicks
这个答案有帮助吗?
得分 2
添加一条评论
Thanks guys. I had the same issue after I did a battery change. I went back in after reading this and found glue debris from the battery was in the digitiser connector.
I pulled out the glue and put it back together. The squares are gone.
Check the connector on the left of the 3. It's long and skinny. If it's not connected properly it can get worse, like heaps of vertical pin stripes.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for this! Inspired to take the cover off for one last time 6th time) and found a micro speck of dust on one of the teeth of the digitiser connection. Blew it off, pressed all connections back on very hard and bingo - back to full normal screen.
完成的
添加一条评论
Look at the touch connector on the screen does it look bent? Like a banana shape slightly? Do u no what I mean?
这个答案有帮助吗?
得分 0
添加一条评论
You mean the connector or the cable ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chuck 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 22
总计 20,799
