跳转到主内容
The Commodore 64 was released in August 1982 and was met with huge success. In March of 1987 the Commodore 64C was released.
Can I use a floppy disk with the C64?
I have a 5.25 inch floppy disk, is this compatible with the Commodore 64?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
The Commodore 64's floppy drive is actually more complex than other PC drives, so other disks are NOT compatible. You'll have to get disks that are specific to the C64.
这个答案有帮助吗?
得分 2
添加一条评论
This a rather interesting drive designed specifically for the commodore 64:
https://en.wikipedia.org/wiki/Commodore_...
这个答案有帮助吗?
得分 1
1条评论:
Alleen de 1541 Drive van Commodore is bruikbaar.
Dit zijn enkelzijdige drives met minder dan 360/2 (180) KB.
Niet alle 40 sporen, maar slechts 35 sporen worden gebruikt.
Met een trucje zijn de diskettes aan twee zijden bruikbaar door deze handmatig om te draaien.
完成的
添加一条评论
you'll need a Commodore 1541 disk drive and it works with any blank or c64 game 5¼" disks
这个答案有帮助吗?
得分 0
1条评论:
You need the "SHUGART" interface protocols on the drive. So it can interface with the timing and positioning.
完成的
添加一条评论
If you are unable to find disks / a working drive, some hardware hackers have managed to emulate it with a Raspberry Pi.
Pi1541
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam Kowaleski 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,570
