跳转到主内容
加入维修社区 - 创建账户
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Why isn't my touch screen isn't responding to my touch?
My touch screen isn't responding to my touch? What can I do to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
6个答案
最有帮助的答案
Any reason why it stopped ?
Was it dropped?
这个答案有帮助吗?
得分 2
1条评论:
I'm probably very late to answer this question,but here are some solutions:
Solution 1: Put it in rice of 24 hours or more.
Solution 2: Try rubbing the screen hard
Solution 3: Knock on your phone (the screen is probably stuck)
Solution 4: This one is risky but the best: Deasemble your phone and assemble back again.
Hope this helped!
完成的
添加一条评论
If there is a screen protector on the screen, first remove it. Sometimes the protector interferes with the touch sensitivity. If the screen still doesn't respond, try resetting the phone. If problem persists, display assembly must be replaced.
这个答案有帮助吗?
得分 2
1条评论:
Hope this helped!
完成的
添加一条评论
I have the same problem. I't seem to have some kind of time delay in the software. Sometimes the tuschscreen works fine, and suddenly the screen stop to take any commando when tuching the screen.
Have nothing to do with the protector. I have tryed with and without the protector.....
这个答案有帮助吗?
得分 1
2条评论:
And by the way, when running the internal testprogram, the screen tuch works well.
完成的
Hope this helped!
完成的
添加一条评论
my screen not move at all, also unable to shut down to restart or reduce the volume. How to fix it.
这个答案有帮助吗?
得分 1
添加一条评论
Same here guys, mine isn't responding to my touch too. Anyone has any idea how to fix it? I don't have a screen protector or anything on the screen but yet it still doesn't respond sometimes. Halp plz.
这个答案有帮助吗?
得分 1
1条评论:
Hope this helped!
完成的
添加一条评论
Hope this helped!
这个答案有帮助吗?
得分 0
1条评论:
i cant use my fingers on the phone only the s pen , is that how it was programmed or it can be changed
完成的
添加一条评论
添加你的答案
Brittany Gail 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 40
总计 2,498
