跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
No Bluetooth, greyed out wifi after screen removal
I removed the front panel and screen and reinstalled, afterwards I have no bluetooth and Wifi is greyed out. I am not unfamiliar with electronics repair, but have never had an iphone apart. Anyone have any suggestion where to begin to look for a problem? I didnt removed or detach anything from the back of the phone, just the display side. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Also, the bluetooth isnt going on or off either, and the 'change with buttons' setting is ON in sounds settings. Volume up button doesnt take photos either. Everything appears intact, I removed the front panel again.
完成的
You've never taken a iPhone apart and you start with the most expensive?
Y did you even take it apart?
完成的
I cracked the screen, I ordered a replacement and attempted a repair.
完成的
Courageous. Although iPhone 6 isn't very difficult to open up.
完成的
添加一条评论
1个答案
已选择的解决方案
Dead wifi/bluetooth chip. You probably shorted/knocked some components off when removing the display cable or you did not properly discharge yourself of electrical charge, causing ESD to the logic board.
这个答案有帮助吗?
得分 2
2条评论:
Thanks. I figured as much. I am going to get a replacement phone this week, which will fix all of my problems.
完成的
Replaced the display and getting Apple service? Good luck.
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,500
