My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
这个答案有帮助吗?
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 1,718
