iMac 17" Works perfect only on Safe Mode
Picked up this White Imac 17" for $20.00, seller said Imac was dead....first boot went to screen with some artifacts and then it freeze. Try resetting PRAM and SMC...still same effects, I booted into safe mode and everything works perfect, no issues whatsoever, rebooted to normal, same issues as before. I figured that maybe a bad driver, so I started loading OSX Lion from my USB drive, everything looked fine during installation, no artifacts whatsoever, but when the final reboot to enter for the first time, back to artifacts and freezing....any help would be appreciated.
12条评论
Can you give us the last three digits of your serial number so we can correctly identify which model you have.
由 Dan 完成的
VUX is the last 3 letter of the serial, the bottom plate shows to be 17in/2.0ghz/1GB/160/SD/BT/AP. EMC # 2114
由 chrisimo 完成的
From EveryMac: This system can run the last version of OS X 10.7 "Lion" if upgraded to at least 2 GB of RAM. Although it has a 64-bit processor, it has a 32-bit EFI and is not capable of booting into 64-bit mode. It does not support "OpenCL"
由 Dan 完成的
I would still try Snow Leopard Vs Lion
由 Dan 完成的
Hi Dan... Thanks for your fast response... I did upgrade to 2GB RAM... Im installing Leopard into it as I write this from my ipad... Will let you know the outcome
由 chrisimo 完成的
显示更多的7条评论
