跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Charging/ home button Problems after cell antenna replacement
My phone got wet and everything worked fine except for cellular service, so it was pretty useless unless on wifi.
That to me, meant I needed to replace the cellular antenna. Because that was the only thing not functioning.
Ordered the part, everything went smoothly, until I turned my phone back on.
First off, still no cell service. Then I noticed my home button no longer functioned. So I had to reboot every time I wanted to go back on my phone.
I was prepared to deal with that, but my battery dwindled, I plugged it into the charger annnnnnd no charge. So now my phone is dead and won't charge to turn on.
My only thinking is that I used a bit too much isopropyl alcohol when cleaning some of the connectors in the phone. I used a q-tip and just dabbed a little, not like I poured rubbing alcohol on everything. But shouldn't it have just evaporated anyway?
Any suggestions would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would check that the dock connector is plugged in correctly on the motherboard as the dock also controls the home button..
If it is connected probably and still nothing then you have most likely damaged it and need a replacement dock
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 40
