跳转到主内容
Released in July 1983 in Japan, the Nintendo Family Computer, or Famicom, is the matching predecessor to the Nintendo Entertainment System (NES). Model HVC-001.
10 个问题 查看全部
Blown Fuse / Smoke on Famicom?
Hi All,
Excuse my naivety. I purchased an original Japanese Famicom in Super Potato, Tokyo recently for use in the UK.
At the counter I requested them to provide power supplies - I was provided an RF Switch and Japanese AC Adaptor (100V AC 50/60hz with 10V DC 850mA)
Upon returning, I purchased this RF Cable: http://www.ebay.co.uk/itm/RF-Cable-Super...?
So I hooked up the RF Cable (didn't use the switch), and combined a Travel Adaptor + The AC Adaptor I was supplied with the Famicom and immediately after switching on, I noticed white smoke coming from the Famicom and a pop/bang noise after 5 seconds.
After realising I should be using a step-down convertor or a plug with the current AC Voltage I purchased this and tried using it tonight:
http://www.ebay.co.uk/itm/151415102678?_...
Unfortunately, the Famicom now when turned on doesn't seem to emit any noises or sounds, and the temperature remains the same so I can only assume it's broken - perhaps I've blown a fuse?
What's the best thing to do here?
Option 1) The Famicom is dead, I should just give up
Option 2) Is anyone here based in London that could perhaps take a look at it? I'd be happy to pay for your time & parts
Option 3) Is it possible I've blown a fuse or something that I could fix myself in a straightforward way?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Sounds like a blown fuse.
It's very easy to test for with a multimeter and is a half hour job. You need a 1.5 amp axial quick blow fuse. You can buy them on eBay UK for a couple of quid.
However, assuming it's the original model with hard wired controllers, you might find it difficult to get a TV that can tune in to the famicom RF Signal. I AV modded mine.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Pete Campbell 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 13
总计 2,876
