跳转到主内容
The GravityLight is a gravity generated light source that involves the movement of weights to power a LED bulb.
Why do the bags of rocks not move?
I have filled both bags of rocks and the bags won’t move. I tried to empty out the bags and refill them, but that still didn’t fix my problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Stripped gears are the likely cause for the GravityLight to become jammed. Since the gears are damaged and cannot mesh properly, the gears will become stuck. The gears will need to be replaced by removing the front panel and the frame. Instructions on how to access the gears can be found in the Internal Gear Replacement guide.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jamie Forslin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 367
