跳转到主内容
The GravityLight is a gravity generated light source that involves the movement of weights to power a LED bulb.
Why does the light not turn on?
I have filled in both bags of rocks and the bags are moving on the belt. Despite this, the white light is not turning on and the red warning light is not turning on either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If neither light is illuminating, then no power is reaching the LEDs or the LEDs have burned out. If no power is reaching the LEDs, then the motor has burned out and will need to be replaced by taking the front panel, frame, and gears out. Steps to remove the motor can be found in the Fixing Post Replacement guide. If the LEDs have burned out, both LEDs will need to be replaced; replacing the LEDs involves removing the front panel. Information on how to replace the LEDs can be found in the LED Replacement guide.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jamie Forslin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 372
