跳转到主内容
加入维修社区 - 创建账户
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
How do you remove LCD from case
It looks like around the hinge the LCD casing is broken. I would like to replace the casing without replacing the whole LCD.
How do I open the casing so I can see which side is broken.
I can be reached at
Thank you for your help
Erik
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
machead3
Great Link
It's exactly what I needed
Thank you
完成的
添加一条评论
2个答案
已选择的解决方案
Once you get the top off the bottom
It should be very evident which one is broken see: http://www.PowerBookmedic.com/mac-repair... Display removal followed by hinge replacement.
If this answer is acceptable please return and mark it.
Good Luck,
N.
这个答案有帮助吗?
得分 2
添加一条评论
It's a difficult repair to replace the LCD casing on the PB Titanium since it is glued to the LCD and hard to glue it back in place. You could find a whole replacement display assy for cheap if you search the web (ebay, craigslist, etc).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Erik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 1,933
