跳转到主内容
Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
108 个问题 查看全部
Bose QuietComfort 15 Headphones do not block out noise.
They work great till I get on a really loud lawn mower, then all I hear is the lawn mower. I have had these headphones may be a month.
Update
Thank you, But the headphones worked great the first few times I used them. Now they pick up the sound of the motor. I bought these headphones for this purpose.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Hi Deb,
Noise cancelling headphones are great for quieting low frequency and ambient sounds; airplane engines, air conditioners etc. But unfortunately don't work as well cancelling mid to high range frequencies. The sound of your mower is likely just too high and loud to be cancelled out by your headphones. I would suggest something that provides more noise isolation, a physical barrier between your ear and the sounds, like ear buds.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
My set of QC 15s worked great with one mower. I could listen to podcasts and music with no problem. I recently purchased a new mower and now the noise cancellation pulsates in and out. After doing a bit of quick research I believe there is a frequency difference between the old mower and the new one that is different enough to now make my QC 15s ineffective for use while mowing the lawn.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Deb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,456
