跳转到主内容
The Samsung Galaxy S4 Active is a rugged version of the Galaxy S4. Currently, it is only on AT&T's 4G LTE network.
39 个问题 查看全部
问题已关闭
My s 4 having signal issue. Please help
I bought a used s 4 and I just noticed it has signal issue. It shows the signals but when I try to make a call it drops all of the signals and call gets disconnected. I can't even receive a call. Please advice.
Thank you so much
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
To open the phone and make sure if it have the signal cable or if the signal cable is broken.
这个答案有帮助吗?
得分 0
添加一条评论
Change your SIM card.
这个答案有帮助吗?
得分 0
添加一条评论
Open your phone and unscrew(12 screws total)/GENTLY pry off your midframe. On the right side of your battery housing there is a Long blue Wire with a connector on each end. (This is your antenna) Carefully make sure they are securely fitted on the motherboard and daughter board. (Top and bottom computer boards)
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 178
