跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Damaged display
My LCD Panel tore in the lower right corner (diagonally). It is functional in the rest of the display. Can I modify the display to only use the remain section (programmatically)? That is, project the image to a smaller area of the LCD.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ouch!
Sadly there is no real way to alter the image area so only a section of the LCD is used for the desktop. But you can leverage the given applications window so its over to one side. From what you describe that is not what you want.
Your other alternative here is to use an external monitor until you can get your system repaired.
Sorry ;-{
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
barry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 368
