跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
iPhone touch screen unresponsive when at low battery?
3 weeks ago I fell into a river and my iPhone was in my pocket. I immediately pulled it out, it wouldn't turn on/was dead. I tried the rice trick, and after 48 hours phone works fine although touch screen does not work on small spots.
Today however, the touch screen would be unresponsive for first few seconds after turning on phone, then would be perfectly fine afterwards although slightly sluggish. As the battery goes down through the course of the day this period of unresponsiveness gets longer and longer, until at 50% the touch screen is completely unresponsive, no matter how long I wait/swipe. Is this a hardware issue? If it is, is it fixable/worth to fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The treatment u needed is IPA soaking method.
The rice soaking the moisture but a lot of places (I presume) is corroded!!!
U very lucky that your phone i partly functional but what u should do is open it up (if u don't have the skills go immediately to some lab) and brush the board and the connectors with IPA (http://en.m.wikipedia.org/wiki/Isopropyl...).
Oh and by the way:
When electrical device is got wet u should never try to turn it on with the same battery!!
Good luck david and let us know if there is some changes!!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 1,662
