跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Quality of replacement glass
Do any of the replacement LCD assemblies use gorilla glass? I've looked online and have been unable to prove what kind of glass is used in the replacement digitizers. Previous replacement parts I have used all seem like good, quality parts but the glass seems weaker. Maybe it is thinner? Any insight into this would be greatly appreciated.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I can't tell you the material of the glass because that need to test. But i can tell an easy way to distinguish the original touch panel with custom one, and the original one is absolutely high quality and has same material with your own.
1. Pay attention to the part inside of the red circle, the picture 1 is custom, and picture 2 is original. That's the main difference and the necessary criterion of judgment.
2. Their weight are a little different. The original one is 15.4g, the custom one is 16.4g. But that's not the most important.
3. Also can see the QR code.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Brad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 153
