跳转到主内容
The Lenovo IdeaTab A2109 is a 9-inch multi-touch screen tablet released on August 27, 2012.
My tablet wont boot or charge
When i plug the tablet into the charger there is no response and when i try powering up i get a quick flash and vibration alhough it doesnt boot up, i have tried holding the volume+ and pressing the power button for different lengths of time and still nothing, the product is a little over a year old, it is a 'lenovo tablet pc ideatab A2109A-F' model:2290, any help would be great thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
9个答案
最有帮助的答案
i have same problem
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem
这个答案有帮助吗?
得分 1
添加一条评论
my tab is continuously booting. how to stop that
. lenovo idea A2109A model
这个答案有帮助吗?
得分 0
1条评论:
Had same with A3300-hv just press volume up and down and power off button together it will work for booting
完成的
添加一条评论
MY Lenovo IDEATAB A2109A is booting continuously when i swictedon and iam unable to any program with that pls help me to resolve this problem
这个答案有帮助吗?
得分 0
添加一条评论
The problem could be you battery or io port if you don't feel vibration. Its possible that the screen might not work too.
这个答案有帮助吗?
得分 0
添加一条评论
I have this same problem and everything I try to do it just doesn't work
这个答案有帮助吗?
得分 0
添加一条评论
my screen wont turn on or take charge any more
这个答案有帮助吗?
得分 0
添加一条评论
Has anyone thought to check the USB charge port by wiggling(GENTLY) . to see if a solder contact has failed???????
这个答案有帮助吗?
得分 0
添加一条评论
Hello! First try charging for 5 hours after doing it while plugged press volume up and down and power on/off button together you will get a vibrate ! . its a good sign. Try again for 30 seconds . Hopefully this will work!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
che gee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 39
总计 3,366
