跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
wifi incorrect password after battery change
Greetings,
I am using IOS 6.1.3, and after changing the battery, my WIFI will not connect. I have reset the network settings and fixed the clock to get my service back, but when attempting to connect to WIFI, it almost immediately says "incorrect password". It's like it doesn't even ask the router if it's correct. However, when I disable router security, the phone connects. I am not sure what's going on. I've tried resetting the network settings and rebooting the phone. I have not tried restoring the phone, and would prefer to avoid doing that.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Make sure your using the correct password
这个答案有帮助吗?
得分 0
1条评论:
pretty sure it's the correct password. i even tried changing it to a simple 11111111 on WPA2 and it still won't connect.
完成的
添加一条评论
What you might try doing is update the software. A lot of people don't like the new iOS but, if you don't update, smaller issues like this may occur.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adeel80 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,142
