跳转到主内容
The Cuisinart Mini-Prep Plus DLC-2A is a compact food processor that has been in production since 2001 and retails for about $40.00.
Why isn't my Mini-Prep Plus turning on?
The chopper is not responsive when the chop or grind buttons are pressed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
I've only used this machine a couple of times and it worked perfectly. Went to use it today and no response. I've done all the trouble shooting tips.
完成的
添加一条评论
2个答案
最有帮助的答案
Also, ensure the plastic tab of the bowl cover locks into the slot on the back of the machine. This will short the safety switch.
这个答案有帮助吗?
得分 3
2条评论:
Thank you so much.
Saved me buying a new one.
Philomena
完成的
Bought mine at a yard sale and had no idea. This was the fix. Thank you.
完成的
添加一条评论
Check and ensure that power cord is plugged in. If the power cord is plugged into a working power outlet and there is food inside the workbowl, try removing some of the contents and attempt use again. Failure to "turn on" may be caused by overloading the workbowl to a point where the contents prevent the motor from functioning properly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nancy deGorter 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 58
总计 6,683
