跳转到主内容
宏碁上网本系列的维修和支持指南,包括Aspire One系列。
Is it possible to replace the SSD with higher capacity?
I have an Acer Chromebook CB5-311 16GB version and I was wondering if it's possible to replace the original SSD with a higher capacity one - also which type would fit?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
i want to do the same thing, would love to know if anyone has done it yet?
完成的
完成的
添加一条评论
2个答案
最有帮助的答案
Yes It is possible to replace your SSD with a higher capacity one. To my understanding, replacing your SSD with a higher capacity one is possible as long as the voltage ratings are suitable. Try some brands like Samsung or crucial !
这个答案有帮助吗?
得分 1
添加一条评论
All SSDs are the same physical size. The process is: you have to clone what is on your small capacity drive onto your new higher capacity drive. The higher capacity drive will accept the results of the cloning. Since the cloned drive will be an exact copy of your smaller capacity drive you will now have empty space left over. Your system can't use this until you link the empty space with the allocated part of the drive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Iacovos Florides 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,055
