跳转到主内容
加入维修社区 - 创建账户
Repair guides and troubleshooting for MacBook Pro 15 inch laptop computers with a non-unibody design.
What is missing in here?
So i have a macbook pro i really dont know much but my hard drive is missing (on the bottom left corner next to the battery right?) and something i dont know the name for is missing also (above the battery) which is green (lol) EDIT Here is a pic without the battery in it. http://tinypic.com/r/311o22p/8
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
In the upper right corner of the photo (which is what I think you mean by bottom left here) is the space for the hard drive. The cable to connect to the hard drive is still there; any 2.5" SATA hard drive should work. The space is fairly thin, so you should use a drive that's 9.5mm or thinner; but most laptop SATA drives made these days should fit the space.
What's missing from the socket in the middle of the photo is DDR2 RAM (PC2-5300) - one or two sticks. How much RAM your machine can use depends on the generation of the machine; it ranges from 2GB (2x1GB sticks) to 6GB (2+4GB sticks).
The generation/model number is marked on the back. A1150 has a Core Duo CPU; A1211, A1226 and A1260 have Core2 Duo CPUs. We'll be able to give you a lot more guidance once we know what machine we're dealing with.
这个答案有帮助吗?
得分 1
1条评论:
I would add you should see if the system is even working by first installing a memory module and seeing if the system powers up (power adapter & battery). Even without a hard drive you should see a blinking question mark. I suspect the system was stripped because it is not working anymore.
完成的
添加一条评论
添加你的答案
Eduardo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 79
