跳转到主内容
Miniature one watt version of the classic Marshall half stack. With a tone knob and overdrive channel, it offers portability without sacrificing playability.
7 个问题 查看全部
Micro Amp Battery power not working.
My MS-2R micro amp by Marshall has never failed me in the past but I recently noticed that when I try to use battery power it doesn't work. The wall input works and sounds fine but the battery power doesn't work. I have replaced and used at least 3 different batteries but still no solution.
please help, have a nice day
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Had same problem
I Took the thing apart and there was nothing wrong, I took the wires off the battery contacts and put them directly onto the battery and it worked. So I discovered the problem was the battery wasn't wedged up against the the contacts hard enough. So I cut a piece of card and folded it in half and wedged the battery in there. Switched it on and it started first time, never had a problem since
这个答案有帮助吗?
得分 1
1条评论:
Ahhh thank you!! This worked for me - I also had looked inside and all wires seemed fine - did as you suggested and bingo!
完成的
添加一条评论
添加你的答案
Jellyfish 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 36
总计 3,032
