跳转到主内容
The Samsung Galaxy Grand is an Android smartphone manufactured by Samsung Electronics and released in January 2013. It is also known as the Samsung Galaxy Z I9082Z in India. Models: GT-I9082, GT-I9082Z, GT-I9082L.
51 个问题 查看全部
battery drains fast even after replacement with new battery
my battery drains quickly even after replacement with new one
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
添加一条评论
4个答案
最有帮助的答案
Make restore factory setting
It's working 100%
这个答案有帮助吗?
得分 3
2条评论:
it is working great
完成的
I did factory reset...
Still having the battery issue. When it gets to 70% after full charge. It goes off. Bought another battery, observing same issue.
完成的
添加一条评论
This is a common problem in most Galaxy phones,
#Make sure the replacement battery is original and not a knock-off
  1. Try not to run many apps at the same time
  2. The phone (or the battery) could not be faulty, the Galaxy Grand is supposed to operate for 3-4 hours with a Li-Ion 2100 mAh battery
  3. Consider buying an external power bank (battery) This power bank should last with you for a good 15-20 hours before needing to be recharged.
这个答案有帮助吗?
得分 1
添加一条评论
this appear when the phone have 3 problem 1- maybe the pf ic is damage.2- you charging is not work good 3- you have a lose connection in charging part
这个答案有帮助吗?
得分 0
添加一条评论
Try using ShutApp its a task killing app the "Force stops" apps running even without your notice. Most of the running apps drain your battery really quick as soon as you turn on mobile data or WiFi so I recommend you use or download ShutApp.
这个答案有帮助吗?
得分 0
1条评论:
I dont know how it works
完成的
添加一条评论
添加你的答案
inderjit singh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 12,446
