跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36471 个问题 查看全部
iPhone 6 OIS - Conceptually It is possible maybe?
Essentially the iphone 6 and the 6+ are the same, they both use the same components with the exception of one having a larger screen and one containing optical image stabilisation. If we think about it sooner or later there will be aftermarket parts for the iphone 6. Does anyone else see it possible to install the Iphone 6+ OIS camera onto a Iphone 6? This wouldn't be possible on the previous generations on Iphones, but ideally now, it could!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I think your over simplifying this.
While it may appear the phones are the same the physical parts are not necessarily interchangeable.
Just looking at the iPhone 6 & 6 Plus tear-downs the connections of the camera modules appear to be different.
这个答案有帮助吗?
得分 2
添加一条评论
If it was possible, they wouldve added it
这个答案有帮助吗?
得分 0
1条评论:
I'm not sure if thats the case. I think there could have been a supply issue (limited quantity) or, Apple wanted to make the Plus model have some distinction from its brother.
完成的
添加一条评论
Over half of the pins on the connector are vacant anyway, so the same pin layout does not mean the same circuit. i bet on iphone 6 the wires for OIS are simply not present.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
xxjuiceboxx123 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 212
