跳转到主内容
Updated in March 2008 with 802.11n Wi-Fi support, the AirPort Express A1264 is a compact and portable wireless network device.
12 个问题 查看全部
Can I repair an Airport Express that died from overheating?
The smell started 2 weeks before it died but it worked fine until an hour before it died. Then the signal decreased to the point that the internet slowed to unusable, but my iPhone had a great signal right up to the demise. Is this repairable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
We had a similar issue around the office, which we talk about how to fix here. They talk about it in the article, but it bears repeating here: This is not an official iFixit Guide, do not expect prefect results if you attempt it. We published it more as a hack-fix interest piece.
这个答案有帮助吗?
得分 1
添加一条评论
To answer that question you need disassemble your Airport Express and look after burned parts on the Logic Board and exchange them. If there are no burned parts on the Logic board the broken part presumably is the power supply which can be changed fast&easily.
这个答案有帮助吗?
得分 0
3条评论:
Opening the Express is not easy. Given the smell, I agree the power supply is the problem, but you have not exactly provided an answer.
完成的
Yes I coannot answer the question if that is repairable because that depends on your ability to repair it and on the parts that are broken. Therefore you need to oben the airport express and look after them.
完成的
I opened it and the fuse melted and interrupted the power supply
完成的
添加一条评论
First sorry for my bad english :-)
If the airport is power on but after a while the LED turn off then look for the capacitor on the power bord.
If the fuse i blown then look for the diode is shorted. The LED will be off all time then
If the fuse is blown and its not the diode then change the hold power supply.
If the capacitor is leaking or is not flad on the top change those or test it whit a capacitor tester that the capacitor has is µF
BEST REGARD FROM DENMARK
这个答案有帮助吗?
得分 0
添加一条评论
The fuse is blown and the diode is shorted. And your English is quite good.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christopher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 14,303
