Ps Vita, Battery solder
I was replacing a analog stick on my ps vita. When I tried to remove the battery the clip that connects to the motherboard, it came completely off. Is there a way I can solder the battery wires directly to the motherboard. if anyone can help I would appreciate it. Please Help.
12条评论
Hello I did the same mistake, i wanned to unplug the battery and replug it (i had battery issues) and i broke the solder (actually the black plastic part at the top that hold the wire) so now i can't connect the battery to the motherboard anymore.
Here is a picture of the black plastic i broke :
http://i.imgur.com/YOiIPhQ.jpg
由 Sami 完成的
somebody help please
由 Sami 完成的
Mike, I had the same problem. Or at least a similar one. I was separating the two halves to replace the battery and the entire white plastic cradle part that attaches to the motherboard just came off the circuit board. It came apart effortlessly! It was as if it was barely attached to begin with. Poor quality circuitry!
I'm hoping for an answer here as well. I'm willing to solder if that fixes the issue.
由 mrdeagle 完成的
Have you got a photo so we can see the extent of the damage ? If your in the uk i have a couple of boards knocking around
由 Damian 完成的
https://imgur.com/a/YoOgs
由 Bernard Sawyer 完成的
显示更多的7条评论
