跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Can the iPhone 6 Plus camera fit in the iPhone 6?
One of the distinguishing factors in choosing between the iPhone 6 and iPhone 6 Plus is the camera. If the 6 Plus's camera fits in the smaller iPhone 6 then potentially you can modify the smaller phone to use the better camera and have a phone which is the best of both worlds. Can this be done?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Whether iphone 6s plus front camera can be used to iphone 6plus
完成的
People, I don't care if it were to fit or not. Iphones are unreliable as they are, do not mess up your iphone further and cause some boot loop or fried component.
完成的
添加一条评论
8个答案
已选择的解决方案
Sorry folks they are not the same size so I doubt it will even fit as the plus unit is the larger and has different mounting. See for your selves:
Yes the connectors are the same but we don't know the how the signaling is managed.
这个答案有帮助吗?
得分 3
3条评论:
Thanks for the info.
完成的
it works... just have to stick camera with double tape or some adhesive as 6 camera's size is smaller for 6+ camera housing
完成的
what if we change the mounting for camera
完成的
添加一条评论
supposing you could get the firmware working, the 19 pins I counted on the 6 cam was the same amount on the 6+, id be concerned about size too though im sure someone will measure that out soon enough.
Would be an interesting hack for sure.
这个答案有帮助吗?
得分 2
1条评论:
Yes, I think it would be an interesting experiment to see how compatible it is and how much software would need to be altered?
完成的
添加一条评论
此回答最初是针对另一个问题
Check out this question thread: Can the iPhone 6 Plus camera fit in the iPhone 6?.
As it looks now they are not compatible as the size of the units are different.
这个答案有帮助吗?
得分 2
添加一条评论
A little off topic but 6 and 6s front cams are interchangeable FYI
这个答案有帮助吗?
得分 2
6条评论:
See my post here:
Will the iPhone 6s front camera work on an iPhone 6?
Are you saying you can swap the front cam and rear cams both from a 6s, into a 6???
完成的
front cams yes, not sure on rear cam but I don't think it would work.
完成的
Rear camera NO, front camera yes. And i´m talking about 6 and 6s (not 6+).
完成的
Are you sure that iphone 6 can use 6s front cam ? How abt the quality? If you have an instagram can u pliss dm me? @ssssssafwan
完成的
So is the 6+ front camera interchangeable with the 6 front camera? I know the 6S front camera works on the 6, but how about the 6+ front camera?
完成的
显示更多的1条评论
添加一条评论
I really really doubt if looking at previous phones they made and there interchangablity.
Id say the connectors are completly different
这个答案有帮助吗?
得分 1
3条评论:
Not to mention I am sure the iPhone 6 firmware will not support the motor hardware inside the 6 plus camera. Even if you did get the camera in there working, it wouldn't work as it is supposed to.
完成的
Do you have any evidence that the connectors are different or is that a guess? Also, how are you "sure" that the firmware will not support the motor hardware or is that also just a guess?
完成的
Are they different? Could you look at them? And what about the size? If you took apart the tho phones, it would be possible to check these two things.
完成的
添加一条评论
Any update on this, guys?
I'd love to have the 6 regular with a 6+ cam!
这个答案有帮助吗?
得分 1
添加一条评论
Just hope is it a problem of thickness not allowing it fit in 6 vs 6+, otherwise cheap attitude of Apple regarding expensive price ...
这个答案有帮助吗?
得分 0
2条评论:
I could see this as an issue, dont know how we could get around it unless its only the bit that sticks out. meaning that the camera lens would simply stick out more on our 6s than before.
完成的
seeing how the past iphone components were incompatible i highly doubt it. let us know what you discover though!
完成的
添加一条评论
I can confirm at least with my case that an iPhone 6 camera works inside of an iPhone 6+. I did it on my personal device since my 6+ camera’s stabilizer broke and I had a non-working 6. It works at least for now so I am pretty sure its fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
skemez1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 36
总计 14,586
