跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 个问题 查看全部
No picture on LCD but backlight works
I'm currently working on an iPad Mini Retina wifi and can't figure out why there's no picture on the LCD but the backlight works. It's clear as day that it's lit but nothing shows up. The device syncs to iTunes but I think it needs to be unlocked or something since it won't let me in.
I've tried multiple LCD's and the exact same thing. Not sure what else could be wrong. I'm assuming it could be a fuse or resistor on the motherboard but I don't know which one or where to search for it. I'm assuming it's next to the flex connectors on the motherboard. If so how in the world do I test those? They're like the size of lint!
Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
5条评论
No clue anyone?
完成的
完成的
Did you ever find a solution to this? I am experiencing the same problem now.
完成的
I have this same problem. If I plug back in the old LCD it has a picture. But the new LCD only the backlight comes on, no picture.
完成的
has anyone had a solution for this?
完成的
添加一条评论
2个答案
最有帮助的答案
Tap around the back of the frame. Sometimes this causes it to come back on, for whatever reason
这个答案有帮助吗?
得分 1
添加一条评论
maybe you did not connect the ribbon cable in all the way sometimes that the culprit . sometimes we get in a hurry putting thing back together. or could bent it jus a little.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
npham54 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,418
