跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
My iPhone 5/5s Cracked during repair
http://i.imgur.com/4YldDKI.jpg
http://i.imgur.com/l0SHqhz.jpg
during repair, the iphone doesn't fit completely in the top (second image) and when I try to push in the iphone in, it cracks (seen in first image) why does this happen? is there any way to fix this? It happens on both 5 and 5S
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The screen will fit if the frame is square---assuming it is a quality part.
I've had that happen on the first 5S I did. Every time after that I really try to press the bottom of the phone into the top of the frame as I'm fitting it---never happened again.
这个答案有帮助吗?
得分 1
添加一条评论
It's important to make sure all four corners are shaped correctly for the screen to fit, as they are often bent when the phone has been dropped. There are tools for shaping them (G-tools for example). A file can be sufficient sometimes.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 88
