跳转到主内容
加入维修社区 - 创建账户
由富士通所制造的笔记本电脑。
How to disassembly the Stylistic Q702 for RAM upgrade?
Hi there,
want to upgrade the ram on my Stylistic Q702 but do not know how to disassemble it. I removed the 4 screws on the back but cannot pry it open.
Any help appreciated!
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
It’s not hard to pry open…. pop off the top section at the corners. Then pop off the lower two sections at the corners. It’s just held in by clips. It comes off pretty easily (although I did crack one side of the unit by pulling too hard… so be careful of that… but that was before I popped it off easier at the corners.
I opened mine to add more thermal paste to the CPU. It was generating too much heat and the fan got really loud… now, it’s relatively quiet.
But yes, I couldn’t find the RAM to replace because it is soldered on. I do plan on swapping out the mSATA board in the future though… there’s a slot in mine for the LTE unit… so I need to research that one to see if I can find one to put in here.
这个答案有帮助吗?
得分 3
添加一条评论
Sadly, many of these ultra thin systems don't have room for removable memory modules (soldered RAM). If you read the spec sheet it clearly states permanently Installed
Apple was leader here with the MacBook air and most as thin Ultrabook Windows systems follow Apples lead here.
这个答案有帮助吗?
得分 1
1条评论:
I am afraid to let you know that you can't upgrade the ram on this device. It is soldered directly to the motherboard, as stated by fujitsu in the datasheet.
完成的
添加一条评论
添加你的答案
DonHS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 42
总计 8,563
