跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
My phone is unresponsive, and power button is broken
So basically, my iphone screen went black but was still completely functioning, i was receiving notifications, but i couldn't see them, and obviously i'm unable to reset my phone as the lock button doesn't work. I followed my friends advice and connected it to my itunes to restore it manually. But, before i could restore it, itunes said that i had to update my iphone to the latest version. So i downloaded the update and began to update my phone. And it showed up with a message saying that i have to allow my computer access to my iphone by using the actual iphone itself. Now obviously i can't do that due to the black screen!! Please help me!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First thing til do is open up and disconnect and reconnect the battery then plug in power lead to turn on..
If still black screen then you need to open again and make sure the lcd connectors are seeded correctly if they are and once again still have a blank screen then you will need a new display assembly
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 432
