跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
I forgot my passcode. What will I do?
I want to reset my iphone after changing my battery that i got from IFIXIT. This is the second battery because the first one that i purchased from Amazon did'nt worked, just open and re start repeatedly so i decided to change the battery. It worked but charged only 60% and stopped. I want to reset my settings but i can't reset it because i forgot my passcode until it reached 9 times. And it said it will block my phone if i try once more. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
Restore you phone with iTunes. Do this from DFU mode.
iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - 如何在DFU模式刷机。密码恢复。
Maybe you know - this will erase all your data.
Regards.
这个答案有帮助吗?
得分 1
1条评论:
Thanks it worked. I am now using my iPhone.
完成的
添加一条评论
If you forgot iPhone passcode, then you have lost all of your data unless you've backed up to iTunes or iCloud. You need to do a software recovery with iTunes to restore your phone. You can do this by holding both main buttons while connecting to iTunes. Then iTunes will prompt you to proceed with a software restore. Sorry about your data.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 132
