跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
问题已关闭
New lcd only works with digitizer unplugged?
Hi guys, i am fairly experienced in mobile phone repairs but am having an issue with a replacement screen on a 5C. Customer had cracked glass on old screen but was otherwise working fine, LCD and digi both fine. I fitted a new LCD/digi when i powered it up i got back lights but no LCD. Presumed it was a faulty part so picked up another. Exactly the same issue. Concerned id damaged logic board i refitted original cracked screen. All fine. Puzzled i played around and found that both of the replacement LCDs work fine if i leave the digi flex unplugged. Tried disconnecting and reconnecting battery and a soft reset with no joy. Have i just been unlucky and got 2 faulty screens, can a faulty digi prevent LCD from working?
Thanks in advance
Ollie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I would try a good known working 5c screen not the cracked one..
I'm guessing the screens are faulty no other explanation for it
这个答案有帮助吗?
得分 0
添加一条评论
I just had this same exact problem and I too have been working on phones for some time now. When I finally realized that the LCD worked without the digitizer then I took a close look at the digitizer connection and sure enough it was busted. The top of the connector on the motherboard looked like it was pressed down a little too hard and the metal pins at the top looked partially out of place. So that could be the same issue you are having. I'm going to try and solder the connector back together and see how that goes.
Ok so soldering didn't do anything but the next day I plugged it all back in and placed some pressure on the digitizer connection and it booted up fine. I bumped the phone a couple times to make sure that it wouldn't come loose and haven't had a problem since. The image attached is the connector and notice how the top of it is a little crooked.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 94
