跳转到主内容
加入维修社区 - 创建账户
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Trackpad Button no longer working
So I went to use my computer and it appears the trackpad button is stuck in mid-action, so I can not use the keys to access anything :( I read that it may be a piece of debris as the button feels slightly raised in the center, but either end appears to move freely.
I tried compressed air, but that didn't work. Looks like the fix maybe a new casing or a new computer?
Plan to fire wire back up this week then off to genius bar.
Any thoughts, suggestions.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Follow the guide to remove the top case
inspect from underneath (back or inside) for foreign objects or loose ribbon cables. If none of those are found you can always replace the top case.
If this answer was acceptable please return and mark it.
Good Luck,
N.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Maybe there's something stuck under the trackpad button. You may try to slide a double folded paper sheet under the clic pad to remove the intruder.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Heather 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 2,864
