跳转到主内容
焊接是一种通过在两块金属之间熔化另一种填充金属来连接两块金属的方法。焊接有很多种,但本文旨在教您电焊接的基础知识。
How to clean the tip
I have just bought a copper sponge, but i dont know how to use it properly. Can someone give me some advice please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Basically, you just wipe the tip of the hot iron in the sponge, as if it was wet. Please refere to the following video: https://www.youtube.com/watch?v=1y1xQ0Xe...
Once you are done soldering, you should put a small amount of solder on your tip. This solder creates a protective barrier against the element and make sure that your tip stays as good as new.
这个答案有帮助吗?
得分 2
添加一条评论
Yes you will want to simply wipe the tip onto the sponge. That will remove any excess and clean it off.
Also make sure you are tinning your solder tips when you get them, and after every project. That should extend their life and keep them from oxidizing. Here is a helpful article on tip tinning and care: http://blog.gotopac.com/2013/04/11/solde....
Hope that helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Eden Gage 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 410
