跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
Fixing Keys on Wireless Keyboard
The caps lock key from my keyboard popped out accidentally and on trying to put it back I may have broken the small plastic which comes in between the key and the base.
Is it possible to fix it otherwise or can I buy a separate key from apple store.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
E-bay is your best source for key parts (scissors, nipples & keys).
I have cut and rubber cemented or siliconed nipples (functions like springs or riser) under keys.
The Teflon scissors can also be replaced (it's finicky and there is a "right side up" or "wrong side up" configuration to them). What can not be replaced is the aluminum hinges (little raised tabs with holes for the moving scissors) If they break off you're pretty much done.
The metal arms (on certain large keys and space bar) need to be correctly placed for those keys to work smoothly.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much. I broke those teflon scissors I guess. I'm not so good around technology, everything seems to break in my usage.
Your answer was really very easy to understand. Once again, THANK YOU.
完成的
添加一条评论
添加你的答案
joe bob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 121
