跳转到主内容
加入维修社区 - 创建账户
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Touch does not always work
When touched it does not change or place letter in box, or it places to many letters. There are times when it keeps changing screens without anything being done then it gets stuck on a screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Did this happen after you replaced the screen
这个答案有帮助吗?
得分 0
2条评论:
No this did not happen after changing screens. This is a 1 year old iPad mini.
完成的
I had the same thing happen after I replaced the screen and digitizer but don't know what is wrong.
完成的
添加一条评论
This is solved with a replacement screen.
To avoid this problem:
1.) do not allow the digitizer flex to fold and make a crease
2.) properly tape both the bottom of the digitizer and the home flex to look like the original screen using kapton tape
3.) use an original quality digitizer--plan to spend $40 wholesale, $55 retail--others are low quality
Note:
If you've recently replaced the screen, check for common damage to the digitizer flex socket on the board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 136
