跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
330 个问题 查看全部
Can I replace my 1TB HDD to 256 SSD (2.5")?
I've heard someone said 27" iMac late 2012 motherboard is not support to install SSD. Is it true?
I've read ifixit.com to replace a SSD, but it is not 2.5" SSD. Can I swap out my 1TB and replace a SSD instead?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
All standard SSD's are 2.5" form factor. The one in the guide is a special Apple drive that you would have a very hard time getting.
You can still do this, by replacing the existing 3.5" drive with the 2.5" SSD. All you need it an adapter kit. I'm not sure if iFixit sells them, but I know OWC does.
http://eshop.macsales.com/item/NewerTech...
There are other ones out there, but be careful, not all of them are designed to work with the iMac's mounting system.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 179
