跳转到主内容
加入维修社区 - 创建账户
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
How do I get the cameras to work again?
I have had this phone for 2 months and both cameras stopped working. I try opening the app and it instantly dies and goes back to the home screen. Also on snapchat the screen shows up black and will not show anything that the lens would be showing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 117
50条评论
If there's someone who can help me, my HTC can not take pictures.
完成的
I have exactly the same problem on my camera and other apps such as instagram,snapchat,whatsapp every app that uses the camera does not let me take a picture, Someone please help it's stressing me out now I've had this problem for almost a month
完成的
I have a solution that worked for me! Go into Settings - Power - Scroll down to the bottom and uncheck Fast boot - Restart Phone.
完成的
My sefile is not run. And than dou effect is not work. Now i cant
完成的
unchecking fast boot worked for me! yay thanks!
完成的
显示更多的45条评论
添加一条评论
20个答案
已选择的解决方案
Hi Buddy
My HTC Camera is not working at all, when i tried to open the camera it open and it shows black screen and then after sometime it comes to home scree.
Can you tell me how to rectify this issue.
Rgds
Sameer
这个答案有帮助吗?
得分 58
27条评论:
Help me
完成的
Privacy guard... Yeah.. Problem fixed. Thanks :)
完成的
I didn't find Privacy guard. Where did you find it? The main camera is not working.
完成的
Its worked!! Thank guys.
完成的
Bro, I had also this problem. Now it solved
http://www.gogorapid.com/fix-samsung-gal...
完成的
显示更多的22条评论
添加一条评论
try doing a hard restart . please update the phone software ,
please close all other background app and rsetart the system .
for more follow Guide - steps fix to Phone Camera in phone and try to see if this helps to fix the camera
这个答案有帮助吗?
得分 12
1条评论:
My duo camera stopped working but front camera is still working well please help me .
完成的
添加一条评论
Hey Jacob, here are some things things that I recommend you try:
-Try to 'clear data' under 'camera' in app manager.
-If you're using Lastpass try and do a factory rest.
- If you are using the Lastpass option "Enable fill into apps" and turn it on in accessibility settings then the camera issue might be there. Maybe if you turn it off camera works fine.
-Let me know what happens.
-Hope this helped
这个答案有帮助吗?
得分 6
1条评论:
Please I need help my HTC m8 windows can't open camera
完成的
添加一条评论
SUCCESS!!! first of all thank you for all the suggested solutions. What worked for me? Someone suggested that we should find the apps that use the camera and disable them and VIOLA!!!! that worked for me.
go to settings
then apps
click on each app and scroll to the bottom of each app (each one has to be done individually)
under permissions if the camera is listed you scroll back up and disable the app.
i did not disable messenger though
I VE GOT MY CAMERA BACK!
THANK AGAIN!!!!! HOORAY!
这个答案有帮助吗?
得分 4
添加一条评论
Guys, this is the solution. It worked in my phone.
go to settings then to applications. See which application is using the camera then force stop or disable it. For my case, I forced stop the application called privacy guard and my camera worked perfectly henceforth.
这个答案有帮助吗?
得分 3
2条评论:
how do you determine with app is running your camera
完成的
完成的
添加一条评论
I turned off phone took battery out blew off any dust put battery back and cover it started to work again
这个答案有帮助吗?
得分 3
3条评论:
you can't take the back off a htc m8 because you have to take the screen out to get to the back of them
完成的
Not true mine slips off the back it's a bit hard but does open
完成的
Not sure about m8 my phone is about 3 years old
完成的
添加一条评论
这个答案有帮助吗?
得分 3
2条评论:
no this does not work. stop making false solutions
完成的
This did work for others, that was rude. Not everyones issue has the same cause.
完成的
添加一条评论
When faced with this problem,
1. Review the last apps you downloaded (Settings>Apps>new downloads)
2. Review to see if it uses the camera for any reason
3. If yes, press the Force stop Bottom
4. If 3 above didn't work, you will have to uninstall the app (s)
I did the above and it turned out an app (Swifty) which I recently downloaded, was the cause of the problem.
这个答案有帮助吗?
得分 3
2条评论:
My HTC M8 is brand new from box but camera not working. I have tried to follow all the instructions here but to no avail. What should I do to this brand new hone?
Phillip
完成的
If u installed Security 360 just remove this app and restart your mobile phone.
完成的
添加一条评论
这个答案有帮助吗?
得分 3
添加一条评论
I found an answer but I can't explain it just yet. I have a program that allows my home screen to rotate. Whenever I enable that program the camera does not work in portrait mode. Just get a black screen. However the camera does work in landscape mode. If I disable that rotate program the camera works in both portrait and landscape mode. Not sure what caused this to happen just yet. I thought I remember it working just fine at first. My guess is something got borked and it will take some cache clearing or something to resolve fully. As for now my work around is just to disable the screen rotation when I want to use the camera.
这个答案有帮助吗?
得分 3
添加一条评论
What i did is i just stopped the camera ihad!!and i don't know if this is a option for you-but i just downloaded another camera and it's working nicely! Hopefully so can you!!!!----sue
这个答案有帮助吗?
得分 3
1条评论:
I downloaded a new camera but its
still not working
完成的
添加一条评论
I just opened the back on my phone and fiddled and cleaned it a bit where the connection is, when I rebooted it worked again...
这个答案有帮助吗?
得分 3
添加一条评论
I had the same issue even after factory reset. Then I upgraded my software to marshmallow....
The camera is now properly working
这个答案有帮助吗?
得分 3
添加一条评论
UPDATE I got my camera back for a while, it broke again. I'm tired of trying to fix this. I have had no camera for a while now
这个答案有帮助吗?
得分 2
添加一条评论
I don't have no front camera every time I go to the camera and pick the little square box I don't see the selfie sign.
这个答案有帮助吗?
得分 0
1条评论:
Same issue. Can anyone assist please?
完成的
添加一条评论
My camera won't work the message" camera has unexpectedly stopped " shows up did all the above and a factory reset and still doesn't work
这个答案有帮助吗?
得分 0
1条评论:
I suffering from same issue, if you have any solution please share
完成的
添加一条评论
I had a lot of problems with my htc...
I'm disappointed....
And also my camera doesn't work
这个答案有帮助吗?
得分 0
2条评论:
My HTC Desire 530 front facing camera has also stopped working...did all the above...no help...very frustrating ..can someone please help all of us ? HTC peeps?
完成的
سلام مهسا ، مشکلت رو تو تلگرام بگو راهنماییت کنم
@HaCKeR071
完成的
添加一条评论
Hi
Duo camera is blocked problem after replace camera , plz help me ,
这个答案有帮助吗?
得分 0
1条评论:
HTC makes great phones with too many issues which gives customers tons of migraine. In the long run it's not worth buying.
完成的
添加一条评论
Has anyone contacted HTC and has their phone fixed? I've had my HTC One M9 for 3 days and this has just happened to me.
这个答案有帮助吗?
得分 0
添加一条评论
My camera it's not working
这个答案有帮助吗?
得分 0
2条评论:
My HTC One M8 main camera has stopped working after change of the accumulator battery. Just a black screen. I will try two solutions provided here - turning off "Autorotate" and switching off all the apps that use camera. Will tell you the result soon...
完成的
My HTC One m8 selfie camera is not working camera app quits to menu when I go to selfie mode and on other apps like snapchat selfie can shows black image
完成的
添加一条评论
添加你的答案
Jacob FUEHRER 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 62
总计 189,777
