跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
promity flex cable not working
I replaced power button flex cable on iphone 4s. it does not work i think it is proxmity sensor i think a piece is stuck inside where you press the sensors down overr the little speaker could that be the problem its not working. i got error 4013 in itunes and a white screen when i unplug power cable no errors.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Firstly, check to see if there is a "piece is stuck inside where you press the sensors down overr the little speaker" YES that could be an issue.
Here's the goods on error 4013: http://www.wiki-errors.com/err.php?wiki=...
If you need a replacement part, you can order on through ifixit.com i'm sure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sandra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 81
